Tailgate glass opens while driving
Old 02-22-2011, 05:49 AM
Seldum's Avatar
My Ride: BMW E61 530d 08/2005 (218hp/500nm)
I had the same problem two months ago, and was able to fix it myself.
Theres two things which might trigger the problem you described (to my knowledge):
1: A disfunctional microswitch "quick opener" on window tailgate
2: Corrosion/electrical problem with the wirering near the henges of the tail gate.
The solution to fixing the first problem is to replace the microswitch. I did this myself using a guide I found on this site I believe. I'm not very handy at all so its a cheap and easy fix.
The solution to fixing the second possible problem is a bit more difficult. But theres also guides to do this. You will have to take a look at the right hendge and the wires which goes through there.
I would start out by changing the microswitch, it's easy, cheap and might fix your problem.
Sorry for the bad spelling :/
TexaZ3
05-06-2015 09:54 AM
kennymcd
05-03-2015 08:23 AM
madein
04-16-2015 11:22 AM
Eborlindum
03-23-2015 02:15 AM
08-12-2003 11:41 AM
Quick Reply: Tailgate glass opens while driving
