Suspension
My Ride: 2006 E61 530xi
E61 Owners,
I've been searching the forums and wasn't able to find anyone that had replaced the OE thrust arm bushings with a polyurethane ones. Are these bushings available? I tried searching the net, but had no luck
Would anyone happen to know where to locate these parts?
Thanks in advance.
Thanks in advance.
The bushings currently on the car are torn. So I would need to replace them. I figured to replace them with polyurethane ones in order to prevent them from tearing again.
I'm plan on participating on a few track/lapping days. I would think if the stock ones units were damaged with day to day driving, how long would they last on the track
I agree that there may be some vibration with the poly bushings installed, but I could live with that. I'll have more suspension vibration/feed back when I change the springs and shocks.
My Ride: F11 -14
So far with the little testing I've done with the car, I find the car leans a little more then I would like. It reduces my confidence going into the corners. I'll be making some changes to the suspension to reduce it.
I usually track/race rear wheel drive vehicles. I'm looking forward to the challenges that all wheel drive will be giving me.
Hey Narvselius you mentioned that you have tracked your E61. Did you have any issues of wear with the tension arm bushings?
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
I have the same issues. I really miss the RCS from the non Xi sport package cars...
On of the biggest causes for the excess roll on the North American bound wagons is the Panoramic Sunroof... A ton of heavy glass high up on the car.
I 'm looking in to the Sway bars and larger lower profile wheels and tires to get rid of some of the Added roll.. the Urethane bushings would be great too, but I've yet to find some for a E60/61
I'll replace the sway bars later on. I want to start with springs and struts first and recored the change. Once I have achieved that, my next change will be strut braces etc...
I've spent some time researching the tension are bushings. I found that they are not available. They I thought of making them myself until I looked at how the tension arm works. I believe if the bushings were changed to polyurethane it would be a disadvantage.
It will require more steering effort through turns do to the pivoting design of then tension arm. So I ended up replacing the bushings with OE ones.
08 535i sport pkg
07 E61 530Xi
You have issues with the Spings / Shocks...
Your only alternative due to the Air Springs in the rear Are Coil overs, and the KV3's at that (like $2500-700 USD before tax and install)
And there are some issues with AWD vs RWD on them too.
My Ride: E61 CarbonBlack 535d, Ventilated and Heated Comfort Seats with Massage in Black Nasca Leather, Dark Poplar Wood, Professional Navi, Folding Rear Seats, Load Through, Advanced Remote, PDC, Bluetooth, Dimming and folding Mirrors, Bi-Xenons, Hi-Fi, Tinted
Originally Posted by Nels996' post='1083060' date='Jan 2 2010, 06:32 PM
E61 Owners,
Thanks in advance.
Thanks in advance.
I've developed suspension systems for other cars, so I'm sure I won't have a problem coming up with a solution for the rear.
