Self level warning
My Ride: 5 series 520d touring 2009
So I bought a 2009 5 series touring 2 weeks ago so far .......side lights problem, headlight replacement, both numberplate lights out (stripped wires) and now I'm getting the self level fault pop ip after about 30 seconds if driving and then goes out and doesn't reappear the ride hight seems fine and drives OK what do you think should I panic
No they were loose in the left side pocket in the boot so I have fashioned a foam base for them to sit in so there has been some water ingres problems in the past do you think it could be the relay
Would there be any wiring for the air suspension in the loom that comes through the right hand side boot hinge as I have issues there with split and crimped wires auto electrician is doing a repair this week
dmbperformance
04-22-2009 03:07 PM
