Rides badly in the rear axle - е61
Hello. For a few months the car has been driving very badly at the rear. We have checked everything several times, but the problem does not go away. I changed the rear shocks twice, but the problem is not from them. To the eye and on a lift, everything looks perfect. Any ideas? Is it possible that the problem is coming from the airbags? I used ISTA a few times to calibrate the suspension and everything seemed fine. If anyone can help I would greatly appreciate it. Happy Holidays
If you have a bad bushing in the suspension, it can cause a harsh, sharp "thunk" on bumps. I'd look over the rear suspension closely for torn / worn / ripped bushings, and check the anti-sway bar links.
FWIW, here is a video I did on rebuilding my rear suspension - it's long and detailed, but will give you a good idea of what to look for when working on the (very different from E60) rear suspension...
Tiago
04-03-2007 01:15 AM
