Replace tailgate back up light
Old 12-22-2009, 09:16 AM
Brains's Avatar
My Ride: E61 525D 2005
I have been searching but could not find a topic on how to replace the back-up light (is this how to call it?) on the tailgate. I just don't hope it's the wiring harness (again). Since two days I hear (very annoying ) and see that the left back-up light doesn't wotk. Is there a DIY on how to replace this light bulb?
Thanks for your help.
Old 12-22-2009, 12:01 PM
mmitev's Avatar
which light exactly do you mean?
the white bulb that gets turned on when you reverse?
try opening the cover on the inside of the tailgate, thats very easy. If you dont have access to the bulbs, you will have to remove the plastic trim there, which is much more annoying but still pretty much manageable - its 12 or 13 screws. BUT before that you will have to remove the plastic trim around the tailgate window opening, on the inside of the frame. thats the only way to remove the plastic trim on the inside of the lower part of the tailgate.
(here some emotional memories of me fighting with the destiny to install the LCI lights come alive... and they're not pretty...)
to see pictures, look at Arne's DIY guide for installing the LCI rear lights - it will be of help in any case, if you have to remove anything on the tailgate.
Old 12-22-2009, 12:09 PM
Brains's Avatar
Thanks for your reply mmitev. Yes I mean the white bulb. I'll make sure to check out Arne's DIY but it looks like I am not gonna enjoy this
socale39
09-05-2023 08:30 AM
thesalboy
04-08-2015 09:13 AM
brian1225
04-15-2004 11:01 PM
dv8ed
12-24-2003 07:41 PM
08-12-2003 11:41 AM
Quick Reply: Replace tailgate back up light
