Repair/reconnect the plastic radiator hose connections?
Old Feb 12, 2017 | 12:02 PM
el_cabong's Avatar
My Ride: E61
Default Repair/reconnect the plastic radiator hose connections?
First off - nothing like digging into the engine bay to realize how dirty it is despite the trips to the car wash. Odd issue here, but the search didn't help much. This is on an 06 - so the N52 and oh so common auto.
I had a low coolant message come up on my way home today - and while I'm adding water, I hear trickling over on the driver side. I assumed that my pump or something had gone south - but instead I'm seeing water coming out where two hoses meet - the big supply hose Y from the top of the engine and what I'm thinking is one of the heater supply lines.
Here is where it's leaking from - I moved the hose a little further over to check if it wasn't the return line just under it that was leaking from the same spot. This was taken standing at the front on the drivers side:
So - are these connections repairable or am I replacing that heater hose? Honestly, I'm not entirely sure on how to disconnect and reconnect them. Thank you in advance to anyone that can help.
Old Feb 12, 2017 | 02:01 PM
el_cabong's Avatar
My Ride: E61
I was looking at this picture again and I noticed that there isn't a metal retainer clip like I see on those plastic connectors when I browse ECS or Turner. I went out and could easily separate the two hoses - so maybe I've just lost that retainer clip (somehow) -- is that just a part by itself or do I need to get the whole pipe? And if it's just a case of those coming apart, could I just hose pipe clamp it back together? I'm thinking that the plastic would prevent it from holding - but I'd like to hold out hope.
Old Feb 13, 2017 | 01:42 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
That hose looks like it's missing the metal clip, but I'd venture to guess the hose is just old and worn. I just did a water pump job on my friend's '04 E46 and I had to replace one of the hoses due to a leak at the plastic connector. I'd get a new hose.
Old Feb 13, 2017 | 11:59 AM
el_cabong's Avatar
My Ride: E61
I eventually found the hose I needed and it was $40 - so I think you're right and it's just worth it to replace the whole thing. It's odd because that means that either somehow that clip was recently lost somehow or that it made it 2 years without separating.
Old Feb 13, 2017 | 12:49 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by el_cabong
I it made it 2 years without separating.
luck.
