Remove RH Engine Mounts on RHD e61
Old Apr 23, 2025 | 03:10 AM
Carouser's Avatar
Probation Members
My Ride: e61 lci
Engine: 530i
Default Remove RH Engine Mounts on RHD e61
I am trying to replace my engine mounts on a RHD e61 530i lci. The left side was straight forward, but I cannot work out the right side. All diy's I have seen are for left hand drive, but on my RHD there are quite a few components cluttering the space like the steering box, manifolds, coolant tank, traction control etc. Removing from the top seems impossible and there doesn't seem like there is any room to slide it out from below like I did for the left mount. I was going to remove the engine mount support arm connected to the engine block, purchasing the 4 TTY alu. bolts, but that seems problematic as gaining access to the a few of the bolts is not possible let alone using an angle gauge after torquing.
Does anyone have any advice on correct procedure to remove the right side mount?
scottalexander
Feb 17, 2023 08:39 AM
rkvarner43
DIY: Do It Yourself
26
Oct 27, 2022 03:08 PM
User 21921
DIY: Do It Yourself
Feb 21, 2021 03:53 PM
OldSpool87
May 31, 2015 09:04 AM
frost015
Jul 2, 2009 01:03 AM
