Problems with a couple error codes
Old Dec 29, 2023 | 03:37 AM
danielOlsen's Avatar
My Ride: bmw e61 520d
Model Year: 2010
Engine: N47
Default Problems with a couple error codes
Car started to run rough with ticking/knocking and it was hard to start. Got some fault codes about preheating and such. Swapped out the fuel pressure regulator and sensor. Did nothing. Thought maybe egr or fuelpump. But i have no idea where to continue. Any tips?
Old Dec 29, 2023 | 06:37 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
These codes happened all at the same time or they just started. You have a code of something missing that doesn't make sense? Please clarify.
Old Dec 30, 2023 | 06:32 AM
Model Year: 2010
Engine: N47
All codes happened overnight when i started the car. Came a ticking noice. Was t hard started the first time when all the codes came, but after i started it up it was hard to start
Old Dec 30, 2023 | 07:05 AM
Since I don't know the condition of the car and you're having LIN bus issues paired with electrical issues, how old is the battery? Have it tested. I wouldn't change any parts until I figure the electrical and bus issues out. In addition, I see your glow plug controller is showing up bad which is probably causing all these issues. So check battery and test controller connector and clean it. If power is good at the connector and battery is good, then I would look at the controller.
bimmerdad74
Sep 13, 2023 08:14 AM
Wrightbenz
Jul 27, 2023 07:23 AM
Crepitus
Feb 9, 2023 03:43 PM
Killaduce
Aug 4, 2021 09:49 PM
Davese61
May 12, 2018 12:00 PM
