At low speed I sonetimes hear a popping sound at low speeds when the road is bumpy or uneven. I haven't been able to pinpoint the location, sometimes it seems like it is from the middle (top) and other times at the bottom. I'm thinking a bushing or sway bar??? Not sure. Anybody have a clue?
The strut bearing can wear causing noise. It's also worth re-torquing the bolts that attach the strut brace to the car.
Originally Posted by vanos
(Post 1378726)
Originally Posted by mmitev
(Post 1380263)
check the two screws that connect the strut bar to the firewall, right in front of your navigation display. them being loose is the most common reason for popping from the front/dashboard. every time the air filter is changed, the mechanics remove those screws and sometimes they don't tighten them properly at the end.
Originally Posted by phelix
(Post 1380463)
There's no need to touch those bolts when changing the pollen filters; from memory there are several further components that need removal before you can get to those bolts. I seem to recall there is a TSB on torquing those bolts.
- Antti - |
Did you find out what it is. Mine does it also. As generally I'm an Audi man, and they get the same thing, on them it's the top suspension bearing and buffer.
Originally Posted by Muppet_Man
(Post 1386575)
Stress bar was loose. Tightened all the mounting points and everything is okay now. |
Hi, that's good to hear. Can I just ask what you mean by a stress bar. Is this the same as an anti-roll bar?
Thanks. |
(Post 1386618)
Thanks. |
^^ Correct. Check all mounting points to my sure all is tightened correctly.
