PDC Failure
#21
My Ride: 2005 BMW 535d M Sport Touring Auto Silver/Black
Good afternoon to all, I hope you're having a great weekend. I found this forum site only yesterday and joined up straight away as I could see what a useful tool it could be for this new E61 owner.
I, too, am having difficulty with my PDC. Shortly after buying the car I got the 'bong' alerting me to a PDC fault. The problem has been intermittent for approx 2 months now, sometimes it will operate ok for a few days and then, for no apparent reason, will not do so for the next few days. Invariable, when it has decided that it won't function for a few days it tells me so within a few seconds of turning on the ignition.
I have learned already from this magic forum that I can check the sensors with my thumb and this reveals that only the 2 outer rear sensors are buzzing. I find it hard to accept that 6 of the 8 sensors can suddenly 'go down' at the same time and yet, as there are 2 sensors apparently ok, I guess that the module is ok. Or is it? Any ideas please? I would much appreciate your/any input and many thanks in anticipation.
#22
My Ride: BMW E61 520D 2007
#23
Many thanks Trevorken, I'll try that. I did drive 200 miles yesterday though, which I imagine would ensure that the battery is well charged, and I still have the same PDC failure warning. Any/all additional ideas and suggestions would be very much appreciated. Many thanks again.
#24
My Ride: F11 -14
Hm... I agree it sounds strange that 6 out of 8 sensors should be faulty. What it could be is the control unit for the PDC. Not knowing your car I took a look at my own (530i, production 04/2010) and the article no is 66209145158. If you check the Online catalogue (link below), there is a picture that will explain this better...
http://www.realoem.com/bmw/showparts...&fg=05&lang=en
Good luck!
Good luck!
#25
Good luck!
Good luck!
OK, I'll check out the control unit when I can and make sure all connections, etc., look OK first. Then I suppose I'll have to whip off the bumpers and check out the wiring and sensor connections, etc.. After that I'll probably have to place my trust in an auto-electrician and just hope I don't get ripped off!
Vman33
03-14-2022 04:43 AM
Trinity Autosport
09-22-2016 11:08 PM
bestofthebest
01-05-2016 07:47 PM
