One reverse light dont work
Hello. I have a problem with my E61 facelift. The right reverse light is not on. I changed the bulb, but it still doesn't work. I found that I don't have 12v there, but I do on the left. I tried restarting the module but it doesn't work. Does anyone have any idea where to look for the problem?
Engine: 3.0 B58; 3.0 M54
How do you restart a module. It's already restarted when you first start the car in the morning. I would think if you don't have 12v at the connector to check down the line like fuse or wiring wise. Anything else would need ISTA or INPA to look at codes to see what's going on and run more tests
A8 C1 This is the error code that has
If the problem is in the wiring harness, I don't think I'll disassemble it just for that. Maybe I could run a wire from one bulb to the other and just turn off the burnt-out bulb indicators.
1Animal1
Feb 28, 2012 12:56 PM
