My E61 530d with 20" Bmw style 101 rims.
Old 07-26-2009, 02:20 PM
  #31
Alfonze's Avatar
My Ride: 2005 545iA
Originally Posted by Robbo' post='949043' date='Jul 21 2009, 08:09 PM
Hi,
Are you using spacers? I'm with Style 89 (E65) 9 x 19 + 10 x 19 ET24 and it is really tight both at the front (strut) and inner rear.
/R
I am using no spacers for E65 wheels, and it fits perfectly. I think if your fenders are like sedans, there will be a problem in the back with spacers (i had my fenders rolled when using 295/30 tires, wich is about the same as using 275/30 and 10mm spacers). But since youre going to use so low tires, it might not, needs to be tested... About 275 low profile on 10" wheel is a different story, i think it will look too stretched, i am using a lilltle higher and 285 tire, and i think the 295 would be the right one for this width wheel and profile (but then the ET should be a little higher:-P).
Pic ftom the rear tire (its the default 10" ET24 E65 wheel without a spacer and a 285/35/19 tire):
Old 07-31-2009, 11:11 AM
  #32
Robbo's Avatar
Hi,
The problem with the Touring's are that it is really tight on the inside (the air suspension takes a lot more space than on the E60). This is the main reason I need spacers.
I'm running 275/30's on the rear - wider would no work out due to the cramped space.
I like the stretched look....
Attached Thumbnails My E61 530d with 20" Bmw style 101 rims.-sommar_09_001.jpg
TroyE60
05-30-2019 05:01 PM
Beemer
33
01-14-2019 05:13 AM
bestofthebest
03-30-2015 08:12 PM
JonathonK
03-27-2015 08:13 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: My E61 530d with 20" Bmw style 101 rims.
