M5This E61
Old Aug 1, 2012 | 04:46 PM
  #61
huntington's Avatar
My Ride: 2003 BMW 325i 2008 BMW 535xi Touring 2005 Lexus GX470 2000 Audi A4 1.8T
Originally Posted by jasperxli
uhhh dude i got a square set of 19x10 that i run at the track
Front: ET35
Rear: ET42
Old Aug 1, 2012 | 06:00 PM
  #62
jasperxli's Avatar
My Ride: check siggg
whats the stock offset on the e61? 9.5 will be perfectly fine especially since you have m5 fenders
Old Aug 1, 2012 | 07:02 PM
  #63
norsecarnut's Avatar
My Ride: 2008 535xiT6
Then you should know the tire size is equally important. 19x10 is nothing if your tire is small enough I'd expect stock tire diameter to easily allow the 10" wide rim. Yours may be a little "stretched" too? Tell us the tire size and post a photo!
He's planning to use a 26.75" tire diameter. 245/35x20. I'm running the same diameter and have virtually zero fender liner clearance left to increase size. Mine don't rub, but would if I went up another step.
It's going to depend entirely on that m5 fender liner shape.
I'm very interested to see some photos upon test fitting with the wheel turned and maybe a test with the wheel up onto a curb cut a little to mimic cornering compression.
It'll be good information for those looking to max out the tire size.
Old Aug 1, 2012 | 10:10 PM
  #64
jasperxli's Avatar
current tire size is 285/30 but its probably better to run a 275/35 in the street
Old Aug 2, 2012 | 10:06 AM
  #65
huntington's Avatar
YYYYYESSSSSSSSSS! This is what I was hoping to see! Do you have any rubbing issues? This is on an E61 AWD?
  #66
huntington's Avatar
I'm hoping the M5 fenders and liners clear. If not I will modify the fender liners to make it fit.
Old Aug 3, 2012 | 09:36 AM
  #67
huntington's Avatar
Tires are in...
Old Aug 3, 2012 | 09:43 AM
  #68
huntington's Avatar
Before swapping to the 20" wheels, I decided to replace my front thrust arm bushings. This is incredibly important for the health of your suspension, braking, and the longevity of your tires. An easy way to tell if your bushings are bad is if you hit the brake decently hard while going 5-10mph and you feel a jolt in the steering. You can also feel it if you go over a speed bump or in to a driveway and the suspension feels loose (sorry that's the best way I know to describe it.
Easiest way to figure this out is to get your car on a lift or even a jack and if you can move the front wheels side to side, you need new bushings. Uneven tire wear is a symptom, though that can be caused by improper alignment.
Here's a comparison between new and old:
You can see here that I should NOT be able to separate the rubber from the metal. This is showing that the rubber is old and torn internally. Sorry it's hard to photograph.
More to come...
Old Aug 3, 2012 | 10:18 AM
  #69
jasperxli's Avatar
yea but its not enough to bother me
Old Aug 3, 2012 | 04:17 PM
  #70
Lotus99's Avatar
Hmmm... What's the mileage on your car again Hunt?
