M5 whells 166 on E61!
My Ride: 535d Touring Sport - M Paket - Carbon S - headup display - Steering - Pro Nav - Logic 7 - Panoramic - 135m whells - PDC and all other full Bmw optional light, confort ...
japan owner of E61 say to mount 166M whells into E61 M sport without problem whit tir 245 front and 275 rear!
[snapback]159485[/snapback]
My Ride: coming in March 530d touring individual, messing metallic, platino extended leather, piano black interior trim, M-sport packet, head up display, navigation professional, logic 7, active steering, CD changer, Bluetooth, packet light, adaptive and xenon lights, PDC, heated seats, packet mirrors, panorama sunroof, alarm, automatic rear door
I think there will not be any problem if you put on 245 and 275 on it. I have 20' wheels from 7 with 245 and 275 and no problem at all.
Originally Posted by karelt' date='Aug 16 2005, 05:15 AM
I think there will not be any problem if you put on 245 and 275 on it. I have 20' wheels from 7 with 245 and 275 and no problem at all.? ![Roll Eyes (Sarcastic)](https://5series.net/forums/images/smilies/imported/rolleyes.gif)
[snapback]159758[/snapback]
Bmw dealer are contrasting opinion by the offset of M5 whells is wrong for touring. what to say?
I think there will be no problem I have on my E61 10x20 ET 24 on rear with 275/35/20 the tire is wider and higher then the sock one and I don't have any rubbing. If I look around there is more than 2 cm room around. If you put on 9,5x19 ET 28 from M5 the wheel is thinner and on the ET is just 4 mm difference, there will be no problem.
Originally Posted by karelt' date='Aug 18 2005, 10:08 AM
I think there will be no problem I have on my E61 10x20 ET 24 on rear with 275/35/20 the tire is wider and higher then the sock one and I don't have any rubbing. If I look around there is more than 2 cm room around. If you put on 9,5x19 ET 28 from M5 the wheel is thinner and on the ET is just 4 mm difference, there will be no problem.? ![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
[snapback]160647[/snapback]
for the rear is clear. For the front what is your opinion about the m5 266 whells? the size 8,5x19 with offset 12 . I think ther no problem. What you think? what whells and size you have in your car?
I have 9x20 ET 24 and tyre 245/35/20 I think this is the maximal size which you can put on, becouse if I turn there is just 2 or 3 milimetrs room. But when you put 245/35/19 you will not have any problems.
My Ride: 2008 E60 M5/SMG (LCI)
Interlagos Blue/Black Merino
Aux input, sun protection glass, Bluetooth, Voice control
the 1st and last pics are not aftermarket but Alpina Classics .. like mine!
Model Year: 2012
My535
08-03-2015 04:57 PM
