Level warning symbo & third oil service costs.
Hi to you all. I have not owned my 525d SE E61 for too long but i love it. I am new to the forum, so please be gentle with me if this thread has been posted before.
Has anyone had a problem with the rear air suspension warning light coming on now and again when parker or driving? If so what was the problem, an how was it rectified? I have checked the ride height of the car and all sems fine when the warning symbol appears on the dashboard. The car is a june 05.
Is there anyone in the forum had a third oil service? I went to both my local dealerships and they both quoted me around ?550 & ?600 for oil, air,brake fluid and fuel filter change. Do these prices seem correct to other peoples experience? Now its out of warranty i am going to try a place in Warrington called David Paul. He's going to do the lot for ?252 and stamp the book with an unofficial stamp. Anyone had there car to these guys in warington? They have been there for over 10 years. Thanks for reading
I had the air pump replaced on my E61 and it solved the intermittent warning in the instrument cluster. tThe pump had a small leak and could not maintain pressure, particularly once it started getting colder in the fall.
Originally Posted by bigun' post='667680' date='Sep 12 2008, 04:01 AM
Thanks for that, i have noticed on other threads that it seems to be a common problem. Anyone got the price of a new pump to hand? The guy at the independant BMW garage looked at the car and said the ride height was fine and only replace the pump if the warning light came on during every journey. Knowing BMW, they probably had the pump manufactured incorrectly or they have a design fault. Had a few BMW's like yourself buy i have owned 4 Audis on the trot following the plethra of design faults found on my brand new 318ci back in 2000. This is the only second hand car i have bought in a long time. The way your car sheds cash here in the UK on a daily bases means buying new as a private owner,especialy on a car like this an idotic prospect.
My Ride: E61 530d Touring, May 2004
Re warning indicator, really depends how often it comes on. Mine did so about once every 3-4 months - mostly immediately after start-up and more likely when very cold.
In every case a quick ignition off / on cleared it so never bothered to follow up - as unlikely that the fault would recur when at the dealer, and no change in incidence over 2-3 years.
Originally Posted by ademitt' post='666902' date='Sep 11 2008, 09:30 AM
I had the air pump replaced on my E61 and it solved the intermittent warning in the instrument cluster. the pump had a small leak and could not maintain pressure, particularly once it started getting colder in the fall.
Hi all,
I have got the car at the dealership this afternoon. A quick update on prices for the repair of the rear suspension for people just out of warranty, like me self.
New pump ?557+vat (1 hour to install at ?120) BMW sell 60 a month in the UK
New air springs ?210 each, maybe 2 required BMW sell 15 a month in the UK
New control unit ? 250 No quote for sales per month.
Sensors not priced up.
The new pump price, plus investigation work will cost ?120+?120+?650 total ?890
Hope this helps the E61 owners.
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
Does anyone know how long the fault codes stay in the system, as if this is an intermitant fault - how long have you got to get to the dealer for them to read the computer?
Just wondering, in case this ever happens to me.....
