Level control system manfunction error, rear suspension stays in raised position
Has anyone experience this issue? The car rides very rough when the rear raises up (I assume the air bags are inflating to maximum). I can't figure out what is triggering this to occur. Sometimes the car settles back to level fine and the error message disappears other times it stays lifted for days.
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
My Ride: E61 530XiT
I had a problem with my system last Fall. At times I had the opposite, with the car telling me it was too low and to avoid sporty driving and quick turns. Apparently my pump was going back (at 100k miles). It couldn't compress enough air before the system timed it out. It was an intermittent problem. A new compressor from Arnott (and definitely NOT the dealer) fixed the problem.
A diagnostic scan should indicate roughly where the problems is. A rough ride might also be a lack of inflation and the car is sitting on the bump stops or close to them.
How much was the Arnott compressor?
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
When it happened, I could tell the ride was awful almost instantly, and a few moments later, the error appeared on the HUD. Turning the car off and on did not help, and I forgot my OBD-USB cable for INPA at home (
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
I'll read codes if the snow stops tomorrow and report back.
I'm taking my car into the shop this week. My car is stuck just like your car is shown in the pictures. I really hate these rear air springs. So damn complicated for a feature I don't need or like.
Model Year: 2010
Engine: N54
Well, I read the codes tonight, and the EHC showed the following:
5F92
5F9A
Based on a quick google search, I found the following:
5F92 - EHC: Supply, ride-level sensor, rear left
5F9A - Control-time fault, lifting
If this happens again, I'll check the sensor and signal wiring in more detail. I was worried about the adjustable links I installed with the KW V3's, but everything looked OK based on a quick visual inspection when I pulled over, so this may be more difficult to troubleshoot since it appears to be intermittent. I am interested to hear what codes and resolution your shop finds.
5F92
5F9A
Model Year: 2010
Engine: N54
This happened again to me this weekend, so I lowered the axle manually in INPA until it was at the desired height. I have continued to get the "Level Control Malfunction" error message on my HUD, but the ride height is no longer affected.
Any answer from the dealer on your issue?
Here is what the shop put in regards to the issue:
Replace left rear height sensor
Part number 37-14-6-784-696 cost was $110 and 1 hour of labor to put in in was $98
It's all fixed now.
Model Year: 2010
Engine: N54
That's what I expected. Based on the codes, I already ordered a brand new genuine BMW sensor off ebay for $40. I'll put it in and reset things with INPA, and it should fix this issue. I just need to figure out how to reset the EHC with INPA.
