LCI Cars and Run Flat Tyres
My Ride: 520d F10, Sport Auto, Black, sun protection, Oyster/Black with Anthracite, Ambient lighting.
Originally Posted by mario.kwok' post='979807' date='Aug 17 2009, 10:40 PM
While we are talking on this topic, does anyone know what's the difference between Run flat tyres and Reinforced tyres? I'm thinking about ditching the run-flat and move back to conventional tyres for ride comfort, came across some called reinforced at blackcircles.com. Not sure if I need a space saver for those, can anyone help? Thanks.
Hello all,
I have a 535d E61 with 18" wheels.
The ride with RFT's is is terrible (too harsh) so I decided to change to Reinforced/extra-load tyres and it is much much better now (ride confort and handling).
I needed to adjust tire pressure upward a couple of lbs/psi. I'm not over the recommended settings on the sticker on the driver door . The higher the pressure the hardest ride you get. so you need to find a good compromise
Originally Posted by capbarbaruiva' post='990391' date='Aug 27 2009, 05:33 PM
Hello all,
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
Originally Posted by darkus' post='976296' date='Aug 14 2009, 12:56 PM
I usually use around 32-35
i use 34 front 36 rear, 17 inch P7 normal tyre.. runs better than run flat and it gain 20more miles on the clock per full tank of fuel.
