kw v3 ride and handling on 2009 US 535xit
Greetings from Seattle,
I'm thinking of putting KW V3 coil overs on my US spec 535xit. Can anyone who has done this mod describe the ride and handling characteristics of same? I've seen reports on this on other vehicles that have said ride at highway speeds is a bit bouncy and wonder if this holds true for my car. Also,I'm planning on sticking with my stock BMW 17" wheels for overall ride quality and would not want to lower the car more than the minimum front and rear for clearance reasons. Lastly does this help prevent body lean in corners given stock sway bar currently on car (have not been able to find aftermarket sways for this car in the USA). Thank you in advance for any replies.
My Ride: 2008 Black E61 530Xd - M-sport - Comfort - Advantage
The ride and the handling are excellent for my taste!!! Now I´ve been driving 30000km with KW3 and couldn`t be more happier with it.
Here´s my story and some pics.
It affects A LOT to the body lean. IMO you don´t need to change the stock sway bar, because there´s much less bodyroll with the KW3 compared to the M-suspension (tested last summer).
Mika
My Ride: alpine white 535 E61
Model Year: 08
I cant speak to much about lean, b/c never really noticed it much before the kw's but all I'll say is get them they are worth it . My cars rides just like stock only better. And I run 19" wheels. Mine are set soft as well.
My Ride: Boxster S
Going way back to the archives via a search. Question for those running the KW V3s. Is there an xiT specific KW setup for our cars? I'm assuming that you replace the front spring and strut with the coilover and in the rear, keep the air bags, remove the strut, and replace it with the KW strut. Then adjust rear height via sensors, yes?
I love the stock ride. I wish there were drop hats available for the front of these cars so get an inch lower in the front and keep the rest of the setup stock....
Yep - Manufacturer Part #: 35220074
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
