Jacking up the wagon.
Old Feb 10, 2015 | 01:49 AM
801535's Avatar
My Ride: 2010 535 xDrive
Default Jacking up the wagon.
Bought my e61 and previous owner don't have owners manual inside glove box. Going to change out the wheels on my car. Do you guys/gals suggest disconnecting the batteries before jacking up the car?
Old Feb 10, 2015 | 04:51 AM
mitchgixer6's Avatar
My Ride: E61
I've had the wheels off my E61 without disconnecting the battery without any issues. I think as long as the car is unlocked when you do it you'll be fine.
Old Feb 10, 2015 | 06:53 AM
801535's Avatar
What do you mean by "car is unlocked"?
Old Feb 10, 2015 | 09:21 AM
Lotus99's Avatar
No. What are you concerned about? Like every time you change from summers to winters, disconnect the battery?
Old Feb 10, 2015 | 01:39 PM
801535's Avatar
I have a 2010 Lincoln Navigator, and every time I change winter set to summer set, or change brake pads, its always recommended to turn off the air suspension system before jacking it up.
My concern is popping or over inflating the airbags for the rear suspension.
Old Feb 10, 2015 | 02:30 PM
Lotus99's Avatar
Hmmm... I am hoping that (I only jack the car up twice for all 4 wheels - one side at a time - using the rear jack pad, I can get both the rear and front wheels on that side off the ground, hence saving me jacking up the car 4 times) since it's only for a half hour per side, it's not a big deal.
When I do turn the car on, I do notice that it starts working, so it might have compressed some air out, but hasn't been an issue over a few years so far (crossing fingers!)
And you're shifting only some of the weight to the other side. You're still bearing quite a bit of weight on the jack.
Old Feb 11, 2015 | 09:57 AM
My Ride: E61
I mean the doors are unlocked and the alarm deactivated. Otherwise the car will sense a difference in Ievel, will think it's being stolen and trigger the alarm.
I've never had issues with the air suspension after jacking, I can only presume there's a safety to prevent any damage.
Old Feb 12, 2015 | 03:19 AM
oclvframe's Avatar
My Ride: 2007 530XiT BSM/Auburn
I've never seen anyone disconnect the battery when lifting the car...not at a dealer or at the tire place when I get the tires rotated....
-r
Old Feb 12, 2015 | 07:31 AM
Lotus99's Avatar
Yeah, but he's not talking about lifting the whole car... He's talking about jacking up one side yourself while the other side is still on the ground, hence his worry about pressure on the other side's air springs. But as I said, if you think about it, it's not like 4000 pounds is sitting on one rear air spring. One side of the car is still on two wheels, and the other side is most supported with the jack, so it's paranoia worring about it IMO.
Old Feb 12, 2015 | 08:41 AM
801535's Avatar
Lotus99 is right on what I was worried about. I jacked up the rear end to I stall my hitch and everything was ok... Thanks guy for the input.
er8086
Feb 1, 2018 05:43 AM
ENDEE666
Jun 7, 2016 10:31 PM
aqualibrium
Oct 23, 2015 06:01 PM
PelicanParts.com
Aug 28, 2015 12:12 PM
Ronzo
Jul 26, 2005 12:37 PM
