How to open tailglass if the switch don't work
Is there any way to open the tailglass if the switch don't works?
I can't check/change the switch if I can't open the glass. Tried to remove the trim from the back of the lid but this is impossible I need to open the class for access to 2 screews.
Any ideas? Thanks.
Any ideas? Thanks.
Search function is your friend..
https://5series.net/forums/topic/982...1#entry1167218
Hope this helps
Hope this helps
My Ride: 530 dat. 2005 M-sport, carbon black
The tailglass is now open
Use the prcedure in post #22.
Inside the oval hole there is a metal part with a round hole. Put a small screwdriver in the round hole and move it to the right and the window pops up.
The reason that it could not open was connector just behind the push button. The connection was open and I but it together again.
The connection may have got apart when I fixed the viper as it could almost not move.
Thanks a lot.
Thanks a lot.
TexaZ3
05-06-2015 09:54 AM
