Heatspreading Advanced AC
My Ride: 535dA touring 2005
Sapphire Black, Leather Dakota LCTE 04( name?)
217, 235, 248, 524, 589.2, 609, 610, 672, 677.
Hello again....
After the 535dAt have been at the local shop for upgrade the ACC acts almostly as wierd as before.
When new it spread full heat on the air outlet by the window and by the feet no matter if temp was set for 18 or 25 degrees C. Auto position and AC on. Outside 12-18 degrees. Then i tried to run it manually via the Idrive and still the same problem occured. on the air oulet by the console( middle height) come a lot of cold air. No matter if i changed the air outlet in the idrive to be cold or hot.
Sounds familiar to anyone and how was it solved? 17.x upgrade did not fix this.
My Ride: 525d Sport Touring, Carbon Black, Dakota Black Leather, Maple Wood interior trim
"How much more black could this be? And the answer is ‘None. None...more black’ " - David St Hubbins, Spinal Tap
IMHO the AAC in my E61 is far inferior to the one in my old E46... less effective, far too complex, and downright cr*p when it comes to trying to sort out airflow/temperature on the passenger side... Still, gotta love those classy silver rotary knobs - just the ticket in a ?35K+ car!
skrelnik
09-18-2015 07:24 AM
