Fuel tank leak
My Ride: 535XI
Engine: N54
So trying to fix the threads on my rear right side passenger seatbelt on my 535xi , i used the tap to far down and threaded a hole on my gas tank.
Any DIY out there on how to replaced this since im buying one?
Would like to save $500 or $600 just in labor.
$10 is the max i can go on my tank right now.
My Ride: 530xi Sportwagen
Engine: N52
Well ..... I am guessing the gas tank is some kind of thermoformed plastic. If you can identify exactly what it is made of, then you can use a soldering iron type of welder with proper filler to repair the hole/crack in the tank. Provided you didn't kill some kind of sensor boss or mounting bracket.
There is no open flame with that kind of welder, so fire risk is minimal. Nonetheless, it wouldn't be a bad idea to fill the tank with water before you start welding.
Jose
Jose
My Ride: 535XI
Engine: N54
Jose
Jose
Thanks for the tip, since is on the top i have to get it remove.
FunTT535i
12-11-2015 09:38 AM
DetailersDomain
Detailing Forum
11-26-2015 05:49 PM
