error messages help
Registering the battery as new and setting the Ah rate are two different things.
I was mostly referring to registering the battery as new.
What OBD2 device are you using? Can it read the battery charge histogram?
My Ride: 520D E61 LCI and 318CI E46 CONVERTIBLE
its an autophix 5900. registers battery change but couldn't see anything else on there. just said new battery registered.
I actually have that same device. It only shows new battery registered because it uses Ah learn mode. While the DME/DDE is still learning, it would have your alternator output all over the place.
There seems to be a lot more going on with your vehicle than just the over-voltage condition.
BMW charging system is complex. It is maintained by the DME. So, there are many components to check. I am simply walking you through checking each component.
its in for a recall next Wednesday anyway. something to do with the battery.
Abletobecain
05-04-2023 09:04 AM
Greg530
02-16-2007 07:42 AM
