ECU replacement, propertly ccc coding
Hello guys, recently i changed ecu, and ccc has no sound, how to propertly code it, because now my media settings showing I have logic7 (i don't), I've tried to code cappl, caud, cgate, chost, ctune, no errors, ccc no sound, at the one time there was a sound when coding, but after car restarting, sound disappeared and how to know, I have hifi or simple stereo?
VIN - WBANS71070CP31057
I have dcan cable, winkpf, coding tool, tool32, inpa, ncs dummy, ncs expert.
And I can't rewrite my ecu vin, because of this "coding sequence description file (CABD] 14DDE626.IPO not found or erroneous"
can't find this ipo file in sp-daten...
Thanks for helping me...
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Do not change VIN on replacement. If you default coded it correctly (in certain sequence) everything should have worked. Did you use the default profile to default code the modules?
Jonasss4848 (09-18-2024)
Model Year: 05 530i
Engine: 3.0 M54
What blocks? You're trying to option code not default code if there's blocks. You just need to default code which is staying in NCSEXPERT and default coding the modules. It should take only a few secs each module
