E61 seal between panoramic and roof?
My Ride: E34, E46, E61
LHello friends! Im new here, but I hope to get some help from you! So the problem for my e61 is leaking panoramic sunroof. I figured out that water drains are ok but I dont have seal what comes on the front gutter and comes between roof and sunroof frame (in the picture). Can someone give me the code for this part? Dealer in Latvia cant help me because they dont have the code
help guys!
in the picture you see the front of the car.
Here are that place where the seal have to be
help guys!
Is this the only part# to get for replacing the sunroof seal? how about the piece that is attached to the front of rear glass?
real oem has two part#s, one is 54107199533 (superseded by 54107430946) correct me if I am wrong
and another one part# 54137127565 and it says x2
FCP says they both fit E61
Any suggestions?
Any suggestions?
For E61 that has this type of sunroof, we need the rear glass seal as well, but still confused as to why one would need 2x of that part#, since the actual one goes on to the frame and one that goes between the two glasses.
Went ahead and ordered one of each.
Three suggestions:
- take a moment to clean the drains because they can still clog up over time, especially as yours has had more flowing through it
- you might want to do the work on a warm day, helps soften the glue from the old seal a bit
- the new seal is way better than the factory version, you'll find it so much quieter inside
pavjayt (01-19-2022)
hammar
11-24-2020 06:16 PM
