E61 Restraint System failure (B13B2)
Old 08-23-2010, 07:24 AM
wokingBigBoy's Avatar
Hi,
I had my restraint system warning reset a couple of times it comes up with a error B13B2 something about a ignition circuit.....
Does anyone know what the problem is??
Thanks in advance!
Car: BMW E61 56 plate.
Old 11-02-2010, 12:00 PM
535DA_M's Avatar
Originally Posted by wokingBigBoy
Hi,
Thanks in advance!
Hi,
Same problem my 535d, and same error B13B2.
Does anyone know ?
Old 11-02-2010, 04:05 PM
Kuul4's Avatar
My Ride: E61 535d
Seems to be quite common problem: https://5series.net/forums/topic/491...ure-passenger/
Old 11-12-2010, 08:08 AM
Liam's Avatar
Had the same issue already 2x in 6 months. In my case it meant that the airbag sensor mat in the passenger seat was faulty. You can have the mat replaced by the dealer (expensive, about 400?) or buy an airbag sensor bypass on Ebay.
Cheers & good luck,
Liam
Old 09-21-2011, 02:50 PM
My problem was a loose positive battery terminal. I smoothed the terminals out and regreased. After a reset the problem never occured.
Old 09-22-2011, 01:30 AM
fletchedpair's Avatar
My Ride: 530D
Same problem from me earlier this year, but positive battery terminal connection was faulty so had it replaced. Very expensive as it contains the Safety Brake Konnector (SBK), explosive device which breaks the positive terminal connection in the event of a collision.
daMANiack
07-03-2016 04:06 AM
martys0uth
06-18-2015 02:41 AM
cakes
04-14-2015 04:50 PM
fmusbmw
Bluetooth & Cell Phone Forum
05-14-2004 11:41 PM
08-12-2003 11:41 AM
Quick Reply: E61 Restraint System failure (B13B2)
