E61 radio reception
Old 11-14-2011, 04:27 AM
Akita's Avatar
Does anyone know where the radio is located? I like to take it out and check for connection and possible repair because the radio can only receive 2 FM stations.
Old 11-14-2011, 05:46 AM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
I suggest you open up your rear spoiler and check the underlying diversity module for corrosion, this is a common cause for poor radio reception.
This is even more likely if you have experienced diminished or failing remote locking through the key fobs.
Good luck
Old 11-14-2011, 10:50 AM
mmitev's Avatar
Good luck
+1
Old 11-15-2011, 12:31 AM
fletchedpair's Avatar
My Ride: 530D
Old 11-15-2011, 03:11 AM
Akita's Avatar
Good luck
Thanks for the advice.
Old 12-03-2011, 10:40 PM
V70Cat's Avatar
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
Good luck
Could you provide more details on the rear spoiler and how to open it?
Old 12-06-2011, 12:49 AM
Theo's Avatar
There should be a DIY here on the forums but can't find it at the moment, haven't got my manual here either so I will give a quick decsription.
Will try to append the full instructions later.
- Put a soft cloth on your roof in front of the spoiler, behind the antenna.
- Open up your rear glass lid.
- Below the spoiler you will find a set of bolts, clearly visible.
- Remove those.
- Close the glass lid.
- Slide the spoiler carefully downwards: DO NOT PULL HARD OR MOVE THE SPOILER AWAY FROM THE CAR ONCE LOOSENED!
- The spoiler will come free from its rail-like mounting and will only be attached by the brake light cable.
- Flip the spoiler forward and place it on the cloth you put on your roof, in the meanwhile making sure no strain is placed on the brake light wire.
- You might want to lightly tape the spoiler to the roof rails on each side to prevent it from sliding off.
- Now you have free access to the diversity module box above the rear window.
- Remove the plastic cover of the box and inspect the module, connectors and surroundings for corrosion and similar nastiness.
- If the module is suspect have it replaced and ask for the foam blocks that come with the SIB associated with the water incursion in the spoiler.
Good luck.
Old 02-13-2012, 01:38 AM
Clifty1175's Avatar
My Ride: E61 520d (177) LCI M Sport - Current E46 M3 - Past E36 M3 - Past E36 328i Coupe M Sport - Past Impreza P1 - Past Audi S4 - Past Porsche 968 Sport - Past
My diversity aerial was replaced last year after having exactly the same problems!
Old 10-09-2013, 11:23 AM
Dinnerticketboy's Avatar
My Ride: E61
My problem looks like the ribbon cable is slightly cut, can a replacement be easily found (part number?)
Old 10-09-2013, 03:10 PM
blueswede's Avatar
My Ride: 523 Touring 2006, 328 Coupé 1999
Think you're looking for the number 5 part Single parts f antenna-diversity BMW 5' E61, 525xi (N52) (verify partno with your own VIN).
TopPMP
08-10-2020 04:15 PM
wooboodoo
09-17-2016 01:45 PM
darnell moore
08-09-2015 07:50 PM
Germaniks
08-09-2015 10:50 AM
Bank$hot530
07-12-2015 04:36 PM
Quick Reply: E61 radio reception
