E61 535i touring lpfp help!!!
Need help!!! E61 535i wagon is reading 88psi at idle. I have to turn the car off and on a few times for it to actually go back to reading at 72.5psi. Does anyone know why this would be happening and how to fix this issue?
A lot of important info is missing. Is it causing an issue? The pressure is controlled by the DME. If it's not causing an issue then let it be. If it's bothering you then it sounds like it's time for a new pump assembly. Are you tuned or anything? Has the pump been replaced before? When did this start happening?
(Post 1619777)
Was it having the issue before the tune? I would remove the tune to see if it makes a difference
(Post 1619785)
| All times are GMT -8. The time now is 12:15 AM. |
