E61 530d -04, power loss and problems with doors
Old 11-11-2021, 04:51 AM
  #21
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I remember responding to something that looks the same on Facebook. I forgot what I said but it definitely points the person in the right direction
Old 11-11-2021, 09:49 AM
  #22
tonnizi's Avatar
My Ride: E61 530d -04
Engine: M57D30
I got the power I ate corrected.
Everything works great anyway.
But the k-can line fault is still coming.
So I have a k-can bus stuck now for some reason.
Could TEL / MULF do this?
Old 11-12-2021, 07:00 AM
  #23
tonnizi's Avatar
Engine: M57D30
I have now tried to find the fault by removing the modules one at a time from the container side, and resetting the fault codes after each module removal.
Used out:
- TEL / MULF
- MPM
- PDC
- AHM
- KBM
- LM
- Seat module(drive and passanger
But at least there was nothing wrong with that now.
The error codes have been read and here are the ones:
https://i.imgur.com/AX1JQmZ.png
Module wood picture (ISTA):
https://i.imgur.com/MzBEj8z.jpg
The AHM is off the end of the yard because it doesn’t work anyway
So I still haven't found anything wrong
Old 06-05-2022, 06:38 AM
  #24
tonnizi's Avatar
Engine: M57D30
i still fight with this k-can line fault.
Now the screen has been changed, but the k-can line fault is not lost anywhere.
In one facebook group someone said that Broken MULF could do this problem too. Is that true?
The container is completely dry.
- It would be really nice to get those error codes out.
Previously, there were only strips off the MULFs, and no loops had been put in.
The fault still did not go away.
So should I test now that I put that Loop in there and watch?
Old 07-11-2022, 11:01 AM
  #25
tonnizi's Avatar
Engine: M57D30
I've been researching this for many months now and it seems like it's giving me gray hair. K-CAN Line Fault is still on.
I have used every module of the rear container and the modules of the seats as well. But K-CAN Line Fault does not lose anything.
What would you do next here?
Should we ask a Finnish person to look at something with a telescope?
Old 10-23-2023, 05:53 AM
  #26
tonnizi's Avatar
Engine: M57D30
The problem has been resolved.
A fault for this K-Line Fault.
The problem was as unique as in the container HKL and Trailer module
Guide:
The easiest way is to find out the K-Line Fault by taking one area at a time, for example in my case I started with the modules in the container.
I did this myself:
- All modules disconnected.
- I put one module in place and looked to see if the SAME module from the tree goes green.
If I went green, I went to the next one.
If it didn't go green, I took it off and moved on to the next one
Tigr
12-24-2019 07:38 AM
TGPrince
12-03-2018 02:30 PM
healthservices
09-07-2010 08:10 AM
skylolow
05-22-2008 07:20 PM
mathmos
06-21-2005 04:24 AM
Quick Reply: E61 530d -04, power loss and problems with doors
