DPF problem?
My Ride: Bmw 530d 2004
I think the dealer did it via process of elimination but I have had it checked by an independant today and he confirmed that the fault codes were pointing to the PDF since many of the codes were indicating various elevated back pressures etc..In there experience if the filter has not cleared with one active regen its very unlikely a second one will do much. So its eith replace or remove it. I was shown where the DPF is in my car and its not easily accessible and would be a major job definitely nothing I could handle.
Did they locate it in the engine compartment right after the turbo? This one?
If they pointed out that can, they were wrong, because that is the catalytic converter in a 535d. In a 530d equipped with the M57N2 engine that pointed out can is a combined catalytic converter and a DPF. In a car with a M57N (like my 530d), that can is only a catalytic converter and the DPF locates under the car.
So, I don't have a 535d myself, but I'm pretty sure (according to RealOEM), that all 535d's have a separate DPF under the car... I think you should check it again, if they showed you that can in the engine compartment.
It wouldn't be the first time when a mechanic gets this wrong. I know some individual workshops have washed the catalytic converter instead of a DPF .
- Antti -
My Ride: 535D E61 Sport Touring, fully loaded.
It was indeed in the engine compartment and I could only see bottom. But it is worrying to hear that they could be so wrong! I did see another can in the middle of the car which i initially thought was the DPF. I think I read somewhere that the DPF in 535d could be under the car in an easily accessed poition or near the engine in more difficult to reach place.
Also another independant (but this one was BMW specialist)told me its unheard of for a DPF to be so clogged after just 20K miles that it cant be cleared by regeneration. He mention "maff"(?)air filter/pump or someting like it as a possible area for investigation - this was just on the phone so difficult for them to comment further.
I think I need to have the car looked at by a specialist, DPF removal or replacement is serious bucks according to the info I got today and I would rather be sure. Have taken car back to BMW to at least get them to diagnose what the problem is before I decide how much of a hole its going to burn in my finances. Forgive the pun but it really is driving me mad!!
Once again many thanks for your helpful comments.
You're welcome.
I've learned that even an authorized BMW mechanic don't know everything, neither do I, but before you take any expensive actions you really should get the DPF (that locates under you car easily accessible) washed. Only new things you need for this job, are the seals for both ends and definitely new bolts and nuts. I believe this is the only auction you would need, washing. I could bet a small amount of money for it .
- Antti -
- Antti -
Got the car back and its fully functional and I have to say the difference is simply sensational! I had the BMW dealer replace the DPF as well as a split "charge air hose". Given time & facilities I would have explored the cleaning option but I decided to play it safe even though it hit my wallet to the tune of £1200. On the plus side I have the old DPF (you were absolutely right in the diagram) which I will do the clean as per your experience and hopefully if all works I can sell it and recoup some of my costs. On a totally unrelated (perhaps?) matter - passenger air bag light which has been on for a few weeks now has miraculously gone off so no more bing bing warning when I start the car! Merry christmas!
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
Have had it confirmed by the local BMW dealer. Have read many discussions and have opted for a bypass module. Will let you know how it works out but from everything I have read its quite simple to install.
My Ride: 535d
Model Year: E61 2006
If the DPF is too clogged, it may be that even a forced regeneration doesn't start, even if the rules fulfill. In this case, your choices are:
1) Wash the DPF
2) Cut the DPF open and rip the DPF cells off
3) Replace the DPF with a straight pipe
4) Try to get some manufacturer's cleaner fluid (like Tunap for example)
4) Buy a new DPF
In choices 2 and 3, your car will be in need of reprogramming. The regeneration process has to be removed from the ECU.
1) Wash the DPF
4) Buy a new DPF
My Ride: 535d
Thanks. I had already figured out and the ECU tuner need to have also the DPF removal software to do that.
BTW Anzafin, why didn't you deleted the catalystic? Catless diesels can pass smog inspections without problems. Or you could buy a sport cat and mount it in the middle of the exhaust system. The reason for this is because the turbo suffer alot by having the cat so close. The further from the turbo, the less stress will have, the more heat will dissipate and it will increase its longevity, or the more boost can run and thus more HP.
