Dpf identification
My Ride: 2006 525d M-sport,19" staggered style 95 wheels,custom quad exhaust with modified reiger rear bumper insert,LCI front and rear lights,stage 2 custom remap, DPF removed, cat removed
My car is a uk 2006 525d 2.5 litre and i'm looking at removing the dpf but looking at the diagrams on real oem it has started to confuse me
![](http://i1205.photobucket.com/albums/bb435/mikethepanel/4D2AC8EC-9467-4550-BE53-BA16BA0D622D-1336-00000157E7466010.jpg)
In this pic it says that number 1 is the first cat and number 3 is the dpf
But in this diagram
![](http://i1205.photobucket.com/albums/bb435/mikethepanel/55CA799E-FA48-4D3E-AC56-A8854DB544FC-1336-00000157EC2A4983.jpg)
It says that the box in the pic is the dpf
Any definite help would be appreciated
But in this diagram
My Ride: Bmw 530d 2004
Why don't you just go and look under the car?
It depends on the manufacturing date, and the most reliable way to be sure is to get a look at it.
edit: In newer cars the part #1 is a combined DPF and the catalytic converter. Older cars there is a separate DPF (#3). You definitely need to check under the car. There is a muffler/can in the middle of the exhaust anyway, but the appearance of it tells if it is a DPF or just a muffler (in which case you have a combined DPF/Cat).
If you have a separate DPF under the car, it looks like the #3 in your picture.
If you have a combined DPF/Cat, the separate muffler under the car looks like this (#2):
![](http://www.realoem.com/bmw/diagrams/c/x/205.png)
- Antti -
- Antti -
My Ride: e61 535d LCi mSport, DPF removed, ECOtune remapped
Not sure if this helps but here is a picture of my DPF off my LCI 535d. This is a combined DPF and CAT, it's bolted directly on the end of the turbo.
![Name: IMG_1465.jpg
Size: 308.5 KB](https://5series.net/forums/attachments/e61-touring-discussion-4/162606d1501535364-dpf-identification-img_1465.jpg)
