Diversity antenna
My Ride: Bmw e61
My keyfob stop working and radio lost memory
i cleaned the Diversity antenna and everything was working again. next day when i went to my car the keyfob did not work but radio memory is working
anyone know what could be the problem if it just stop working overnight?
BMW E61 520D 2006
BMW E61 520D 2006
My Ride: Bmw e61
My Ride: BMW E61 530d
Model Year: 2005
Engine: 3.0d
I'd put my money on a tailgate wiring loom problem.
Had the same issue with keyfob not working, turned out to be a few shot wires, actually a lot of them, fixed them, replaced the whole damn loom with some repair kit, key works again. I also had a parasitic current draw issue because of the wires that were shorting there, this is also gone now.
Maybe when you worked around that area to clean the antenna, the broken wires moved in such a way that they made contact again, but after a while they moved again.
My Ride: Bmw e61
hmm maybe but i had water in the antenna and shit
![Stick Out Tongue](https://5series.net/forums/images/smilies/tongue.gif)
My Ride: E61 535xi touring
I replaced mine. Keyless entry back and good range but am/fm not resolved. Thinking we have more going on with the damn hatch wiring. Not too worried about at this point. Maybe dig into some day but not looking forward to the frustration.
My Ride: E61 535 M-Sport
Model Year: 2010
What PN did you replace with? I'm thinking to do this along with my lift-gate wiring repair activities in the next couple weeks.
Not quite related to this particular problem, but do you guys have any idea why the range of my CAS system sucks? Sometimes it works normally, sometimes it doesnt work even when I touch the key to the door and try to open. Most of the time its works better on rear door handles. Forget about locking and unlocking the doors from any distance more than 20ft. To troubleshoot, I did open my D-Antenna module and is as clean as new inside.
Any ideas ???
Any ideas ???
