Deleted Air suspension. Now need coding to remove error.
Old 12-23-2017, 11:30 PM
Zamudio91's Avatar
My Ride: 06 530xi touring
Originally Posted by alexbaldy
I think mine is having issues. Would not guarantee or warrant this module.
I don’t think it’ll be worse then mine. Mine was submerged in water and since it was cold it froze
Old 12-23-2017, 11:39 PM
alexbaldy's Avatar
My Ride: E70 X5M
Model Year: 2011
That sucks
I'll look for it. But after Christmas
Old 12-31-2017, 10:44 AM
julienjj's Avatar
My Ride: 535xi Touring
To delete the suspention, replace the Sequence code PT73 (which means US WAGON BUILD between X and Y) in the VO/FA of NCS expert without writing it to the CAS&LCM with whatever sequence code from an other market that is close but without the air suspention, then code the DSC, & kombi and whatever other module complains about the lack of air suspension. In case no sequence code is found to be acceptable use the sequence code of an E60 which is NV93.
You need to unplug the EHC module, otherwise the car will still give the warning.
Old 12-31-2017, 11:54 PM
alexbaldy's Avatar
My Ride: E70 X5M
Model Year: 2011
Thank you! Will at this after New Year party. Happy New Year!
Old 01-15-2018, 07:30 PM
alexbaldy's Avatar
My Ride: E70 X5M
Model Year: 2011
Thank you!
Now my wagon is error free!
Old 04-10-2019, 06:40 PM
Francisco Ayala-Delgado's Avatar
My Ride: 530XI
Guys, can you tell me what air suspension modules need to remain in the trunk if I delete my air suspension? I bought a 530XI missing with what I believe are the modules for the air suspension. I would rather replace the suspension than try to locate these modules. The only things that are left on that harness in the trunk are some relays. Thanks.
Old 04-11-2019, 01:38 AM
FuzzyWuzzy's Avatar
My Ride: 530iT
Engine: L33
The only air suspension module back there is just the one; can't remember the name though.
And as I've learned, that same module also controls the TPMS...
Old 02-03-2021, 06:24 AM
L33mua's Avatar
My Ride: 2006 530d Pre LCI
the TPMS is the black module, the suspension is the white one next to it.
AndreF
03-03-2021 04:43 AM
anton
10-20-2016 08:15 AM
twidge
04-18-2016 06:10 PM
The_Sauce
DIY: Do It Yourself
15
06-17-2013 05:00 AM
The_Sauce
03-04-2013 09:14 AM
Quick Reply: Deleted Air suspension. Now need coding to remove error.
