Cobb V3, Cylinder 3 misfire.
Hi everyone! Happy holiday!
I just installed the Cobb V3 a week ago. Love the power! but recently started to get this message Cylinder 3 misfire. Straight 3 days already! Thinking to change my Spark Plug but any idea if I should go with OEM or some performance one? If performance plugs, any recommendation? I will be doing the charge pipe and intercooler later. Many thanks
Try switching one of the ignition coils from the 3 cylinder to another cylinder. If the misfire is then on that cylinder, then you need new ignition coils. Thats what happened to me anyway...
I did the carbon cleaning at 48000km (30000miles), now I am at 83000km (52000mile)
Is it time to replace both?
My Ride: 535xi touring
I just did, at 78k miles. If you don't want to spend money all new coils, do what was suggested and swap the coil to a different cyclinder. Try that when you replace plugs as you have to pull them out anyway.
Thanks!
My Ride: '08 E61 manual
Had a misfire in cylinder 6 as well. When swapping the coils noticed cyl 6 one was not very tight. After swap, no more misfires, so no need to buy coils or plugs.
The Bosch OEM plugs are fine and no need to go the NGK route unless you're heavily modified. Hopefully you changed your plugs at the 45k mile mark since that's the recommended service interval for the N54 plugs.
LOL~ After take out the coil pack I found cylinder 2 & 3 has oil inside.......I guess it is Valve cover or the gasket..........Don't know if easy to DIY....
