Another XI wheel fitment question....
My Ride: 2008 535xi Wagon
Hi guys,
I have done some research but still getting not a definit answer.
I know cant different tire diameters with the X drive so here it is. Got some temporary 20s since my oems were worn out. Following specs
Front
20x8.5 w 225/35/20
Rear which I think is were the problem lies.
20x10 w 255/35/20
They fit well but the traction light comes on at 40mph.
Any suggestions for rear size tires to cure this.
Thanks in advance for the much needed help....
Front
20x8.5 w 225/35/20
20x10 w 255/35/20
I have been doing the calculations, but my question is how close do the numbers have to be ...
If I go with a 245/30/20(661mm) rear and 225/35/20(665.5mm) front will this difference still give me problems ?
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
I don't know if this will help, but what you need to find out is "rolling diameter". From what I understand they have to be like 2% of each other. Which is very close. I have seen where even replacing tires of the same size, just due to wear from front to back being enough to send the error.
There's a comprehensive xi wheel and tire thread - you really really need to research (or at least read through) it!
For openers, the tire size you've indicated for the fronts is SERIOUSLY UNDERSIZED (load capacity) and might actually be dangerous for most driving situations.
Even if you're not buying new tires, TireRack's guides will help you identify the proper tire size for your e61 and wheel rim diameters of all sizes. As was already noted, it's important to maintain the correct rolling radius (diameter) as "original" specs. So, cross index 245/40x18 with the proper tire size for a 20" wheel. As always, clearances vary from model to model ... so be sure to spec for a "touring" as it may be different than a sedan (esp with suspension clearance).
So, cross index 245/50x18 with the proper tire size for a 20" wheel.
Thank you fpr the replies guys, decided to buy 4 new tires at the correct sizes, car rides beautifully and I really like the look. 20x10s have a nice deep concave to it.
Just ordered yhe the H&R springs for her and next and some engine mods
Intake
Charge pipe
Down pipes
Chip
Let me know what you guys think...
Intake
Charge pipe
Down pipes
Chip
