8volt to my tailgate headlight - flickering
Old Aug 22, 2013 | 05:30 AM
la3yna's Avatar
My Ride: e61 - 520d
Default 8volt to my tailgate headlight - flickering
Hi,
My right tailgate headlight is not working (LCI, LED headlight)
- Engine on: No light at all
- Engine off, keys out: dim flickering (!)
I measure from 4.0 to 8.5 volt on the grey/yellow cable that enter the light cluster in the tailgate. (Foglight, reverse light is working 100%)
How to fix this?
I recently fixed the wiring to the far right on the tailgate - but as far as I can see, only numberplate light and tailgate lock are using the two grey/yellow cables)
EDIT: I also tested to measure directly to negative on car battery, so not poor grounding.
EDIT: No error on iDrive
Old Aug 24, 2013 | 07:41 AM
la3yna's Avatar
My Ride: e61 - 520d
bumping this..
Old Aug 25, 2013 | 02:34 AM
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
Be carefull measuring voltages to the lights. These use a PWM controlled voltage. So it might be perfectly normal you measure 8V with a handhelt AC/DC meter. Try comparing it with the other side, or even beter use a scope.
Old Aug 25, 2013 | 11:06 PM
la3yna's Avatar
My Ride: e61 - 520d
I measured the other side
- 0v when engine is off
- 13,5v with engine on
other things I can try?
Vman33
Mar 14, 2022 04:43 AM
bestofthebest
Mar 28, 2016 02:47 PM
umnitza
Nov 25, 2015 11:10 AM
Kewill0360
Sep 28, 2015 07:32 AM
Bogdan7
Sep 23, 2015 11:40 AM
