471A Code
Old Jun 26, 2023 | 01:42 AM
Kagrado's Avatar
My Ride: E61, 530D
Default 471A Code
Hello everyone! Can't seem to find solution to this problem, can you please help out?
Issue:
Fault Code 471a Engine oil, critical oil mass - after clearing comes back
Can't do regen / force regen. DPF Full.
Had codes about throttle body, changed it, codes cleared.
My guess is that's why i can't do a regen, so that's why want to tackle it first before going to the shop. Anyone had this code, any clues where to look?
Thanks!
Old Jun 26, 2023 | 02:07 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You have diesel in the oil so your oil needs to be changed.
Old Jun 26, 2023 | 04:01 AM
Kagrado's Avatar
My Ride: E61, 530D
Thank you! This have solved the issue, the code is gone.
I already did the oil change, but forgot i have to reset the oil change. Once i did that, code went away.
nell
Jun 17, 2018 01:28 PM
adwaen
Aug 3, 2016 01:26 PM
5zeries
Jun 3, 2014 09:00 AM
parmblagan
Jun 4, 2010 11:57 AM
Fastdsl
May 2, 2009 10:18 AM
