4 wheel alighnment
My Ride: 530D Touring M Sport manual
Hi, does anybody know if the caster and camber can be adjusted on front wheels of a 2008 BMW 530d E61 or is it confined to the rear wheels? thanks paneuro.
I don't believe caster is adjustable. I think there is a very small amount of camber you can do if the strut alignment pin is still in place. The mounting holes for the front upper strut mount are oblong shaped and allow for a little bit of adjustment once you remove the alignment pin, probably half a degree.
