29e1 and carbon buildup on plugs
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by msportwagon
Consensus seems to point to FCP Euro with their lifetime warranty.
Model Year: 05 530i
Engine: 3.0 M54
btw, what are the risks of having a leaky injector? Does the fuel make it past the piston rings and mix with the oil?
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by kd7iwp
It’s a lot of money to purchase new index 12 injectors. I had 7s and 8s and upgraded to 12s because so many people said to do it on the various forums and my car ran perfectly before and after, so I wouldn’t say it was worth it. Granted, I got a great deal on a used set locally.
If the injectors leak they can cause premature destruction of the catalytic converter, rough starting (due to fuel sitting in the cylinder, fuel getting into your oil. Not the end of the world, but also not enjoyable.
With leaking injectors, I'd be worried about too much fuel in the oil causing lubrication problems, like issues with rod bearings, etc.
The tune is a few months old. The leaky injector existed before that. I just cleaned the MAP sensor, had some oily residue on it. We'll see what happens. As far as the fuel getting into the crankcase, that one scares me the most.
Model Year: 05 530i
Engine: 3.0 M54
