2" Receiver Hitch in USA? Also: Wiring?
#81
Thanks for the tip about REI, I'd forgotten about them! Looks like they give you 15% off when you sign up for a newsletter, so I might just go ahead and use that right away!
For the bar size, they come in 50, 58 and 65. Do you think with a 50 inch bar, I should be able to put a box on (yours is 36" wide) plus two bikes? Or might the 50 not be wide enough?
With a 50" bar, it pretty much looks like it'll be even with the roof edge. But since the 58 is the same price, I wonder if getting larger (58) is safer up front? My only dilemma is I might end up lazy and leave the bars up even when I don't have a load, so didn't know how bothersome / an eyesore the 58" would be since they'd stick out like 6" per side.
How many minutes would you say it would take to take off the bars / feet once you've gotten good at it?
Once you have them set, it's very easy, about 20 minutes to put back on and less to remove. Even easier is when you have at least 2 bike mounts on either side. These act like a structure holding the whole system together. I just release the straps, have the box off of course, and the bars with 2 bike mounts comes off as one unit.
#82
Haha, sometimes the obvious reasons are lost when your point of view is so practical....the "point" is for "looks"
However, you are correct, one can often justify that purpose by also using a wider tire which would provide more cornering traction.
He answered it but I think he already has the tires too.
I think the tire will be just fine on the 9" rim but a 9.5" would be getting past the sensible limit. I don't recall the section/tread width on the 245/40 but my 245/45 look perfect on the 8.5" rims I have and stretching just another 1/4" on each side would probably be just fine.
The tire brand matter too though. Mine are Bridgestone which seem wider in section that a same spec tire but I really like the thick rim lip protection because I seem to be the one who curbs any wheel possible !
#83
You can certainly cut either brand, it's just steel and then drop the end cap back on.
I'll reiterate, the Thule 450 foot has a wider range of fitting even when compared on the same bar. For example, on the Audi I wanted to use the 2100 box, which is a bit long for the Audi B7 Avant roofline (the B8 is a little longer I think) so I had to have the mount all the way forward right into the part where the rail starts to bend down and into the car roof and gets thicker as well.
The strap design of Thule allows a wide range of flexibility here whereas the Yakima grab style would not be able to hold well in that angle and over the tapering rail.
![](http://www.sargentschutt.com/Cars/Chinook/2004-Chinook-4x4-RV/SES7443/282200004_QH7dL-XL.jpg)
#84
What do you use the Chinook for? Looks like a lot of space and fairly easy to maneuver. We have been debating Airstream trailer vs truck with camper (one that could be easily left behind at camp sites) or more rugged like my roof top tent on a real offroad trailer.
Either trailer idea of course allows the vehicle to be more useful for other normal travel and work but my taste in 4x4 suv is rather extreme.
#85
You can get an idea of the size next to other 'cars' - it can be parked about anywhere.
![](http://www.ses.cc/Friends/2008/Retallack-2008/SES8542/288160355_cpYkb-XL.jpg)
Comfy inside:
![](http://www.sargentschutt.com/Cars/Chinook/2004-Chinook-4x4-RV/SES2764/282194836_bziJ2-XL.jpg)
More pics of it here
#86
![](http://www.alaskancamper.org/Alaskan_Camper-2.jpg)
If you're only staying places a day or so at a time, an RV is nice, but otherwise an SUV/pickup and an Airstream (or more offroad-oriented camper) would be my choice these days. Airstream makes a nice trailer with a gear/toy compartment in back (drop down ramp/door). The new Touareg TDI and an Airstream would be a pretty nice combination. The real downfall with a trailer is they suck in the snow. Otherwise, with sway bars, trailer shocks and a good tow vehicle (X5 and others have ESP programming that turns on when the trailer is connected), they're a good solution. Some other friends tow a new Airstream with their Denali, and with two kids and a dog, they're very 'happy campers'.
#87
So does that mean if I wanted, I could add 20 mm spacers on my wheels and still be ok? Rubbing isn't an issue with this car I'm sure, with the stock suspension. Handling wouldn't be affected negatively?
#88
Why didn't I think of that? From behind, I figured it's the tire width usually that catches the eye, but I guess with the wider wheel, esp. in his case (and I noticed in your case too for all 4 of your wheels), his wheel will stick out a nice 20 mm from the stock position, which will look quite nice and aggressive I'm sure, and if there's any extra lip/dish on his rear wheels, then you can't get that look from your usual 8" wheel... ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
![](http://www.sargentschutt.com/Cars/BMW/BMW-X5-48i/SES4621/776578869_yBoMm-XL.jpg)
Remember you also need new lug bolts of the appropriate length as well. Check ECS tuning for decent quality spacers.
#89
I'll put some bars up there and take photos.
What's your thoughts on whether the 58 would be too long or not, if I was to leave the bars semi-permanently on the car during the summer? Was worried the 58's might look crappy if they stick out too far from the roof, and/or I might risk bumping my head getting in the car?
Or did you take yours off each time after a trip?
#90
I generally try to stay away from spacers, and I'd stay in the 10-15mm range at most just to avoid potential vibration issues. Any time I've used wider spacers, I've had vibration problems. I used 25mm (IIRC) on my 4.8i to get the winter tires to line up with the wider 20" sport package fender trim (I was using 19" X6 wheels for winter). I had vibrations in the rear.
