08 E61 oil pressure
My Ride: 2008 , 535Xi, E61
Engine: ?N54
I get an oil pressure warning on cold mornings, sub 30F. I have an Autophix 7910 code reader but I cannot find a way to read the oil pressure to check this out. Is there a way to read this with this tool?
Engine: 3.0 B58; 3.0 M54
It has a live data function so I'm pretty sure you can read the oil pressure. If it's giving you a light it means you're low on oil so I'd add a qt
My Ride: E70 xDrive35i LCI N55 Premium, Comfort Access, Comfort Seats, 4 Zone climate, Vermillion Red
Model Year: 2012
Engine: N55
Have you inspected the oil pressure sender? They are prone to leaking and failure. If left leaking too long, can cause other problems.
I have also seen knock-off parts that would read incorrectly, drives the computer crazy. Would complain there was too much oil pressure, when the car was turned off. Genuine replacement solved the problem.
