Vibration after 20's installed
Old 07-01-2004, 11:22 AM
LouDawg's Avatar
My Ride: 2007 530i Silver Grey (premium, sport, nav)
I just had some new 20's installed and I noticed when I was driving home, a slight vibration when I started getting up to around 40-60 mph. I've noticed a few posts where people are talking about RINGS, you can buy, to cure the problem.
It could just be a balancing issue but if that's not it, I need to find a cure.. Any input on where I can purchase some of these rings would be much appreciated..
Old 07-01-2004, 11:34 AM
Fly Army's Avatar
A few weeks ago I went from 16" to 18" (124s) and had the same issue at the same speeds. Went back to BMW and had the wheels rebalanced and all is great since. Good Luck!
Old 07-01-2004, 04:32 PM
Kiasu King's Avatar
Slight vibration to be expected given the much larger tyres and road surface contact.
Old 07-01-2004, 05:31 PM
redondoman's Avatar
Why not have whoever installed them get the rings for you? It may need spacers, balancing or the tire pressures adjusted.
Old 07-02-2004, 02:04 AM
Re; rings...
Guest
Posts: n/a
There should be no need for rings on a quality wheel setup for your car. These are frequently used for multiple fit applications, but that shouldn't be the case on a 20 " wheel setup. If it is, you've got the wrong set of wheels. Some quality manufacturers use rings, but I've got the feeling that ain't your problem. Most likely poor balancing, our of round wheels, tires, or all three. Hope this helps...
Old 07-02-2004, 11:02 AM
Banned
SilverRush's Avatar
u might need some HUB RINGS.... chek on those and tat should fix ur prob
dsummersm3
11-14-2019 07:50 AM
DILLESTJAMZ
04-17-2016 03:26 PM
PrimeTimeTSA
08-15-2015 02:14 PM
TexaZ3
04-08-2015 10:50 AM
08-12-2003 11:41 AM
Quick Reply: Vibration after 20's installed
