Upgraded my Angel Eyes. Teaser Pic
My Ride: BMW E60
Model Year: 2016
I noticed you took off the piece behind the turn signal. I hope you're not painting that black as well. Your turn signals will be drastically dimmer due to not having the silver/chrome to reflect light off of.
Yup. I did. Also the lens in front are tinted real dark. Messed up when painting it. One side is tinted front and back of the lens. Trying to get it as smooth as possible. But couldn't wait for it to dry. So I said f*ck it. Didn't want to waste time and proceeded with the install. Hope its still visible.
My Ride: ///M5 BEAST
hahaha, i had a similar issue w/ tinting mine. the nite shade paint wouldnt coat very evenly so i ended up doing two very heavy coats...the result, my corner blinkers are only visible at night (barely) and def not visible during the day. perhaps i need to find a super bright bulb option to help me out. anyone ever replace that blinker bulb with a super bright LED or something?
i also see you went with a flat black paint, i went with a high gloss lacquer, it looks amazing in the day and especially at night...a lot of reflection going on...but then again, my car has a continaul Silver Gray & Gloss Black theme to it...
good luck w/ the rest of your install!
Pics this Saturday. Sealed it last night and will seal it with silicone tonight to be sure.
Went with the oscillating tool. So easy. Took like 10 mins to cut the headlight. Not too hard. I would say changing out the projector lens was the hardest. Didn't have the correct bits to take it apart. So I took a shortcut. Literally. I cut the support, took the lens out, popped the new one in and JB weld the support. Got frustrated and took too long.
Thanks. Yea, the VHT night shade sucks. I'm going to get the super bright LED turn signals.
My Ride: BMW E60
Model Year: 2016
As for the turn signals. There is a 7W LED option right now. I bought a set to test, and it's pretty damn bright. It should be perfect for this black out mod. I'll probably test it tomorrow when I am doing another set of headlights and see if the person wants to pick it up.
Actually, I didn't find Nite Shade to be hard to work with. Prep is pretty key though, it's very advisable to sand the surface on the blinker piece.
Where did you get the 7w LED turn signals? I'm going to need it.
