1 Attachment(s)
akarramba! :hyper:
where's the pics DK ?
So you went the Dremmel route? How hard was it?
:bash: I'm selling the car and I STILL wanna do this lol |
I noticed you took off the piece behind the turn signal. I hope you're not painting that black as well. Your turn signals will be drastically dimmer due to not having the silver/chrome to reflect light off of.
Originally Posted by nomis_nehc
(Post 1371924)
hahaha, i had a similar issue w/ tinting mine. the nite shade paint wouldnt coat very evenly so i ended up doing two very heavy coats...the result, my corner blinkers are only visible at night (barely) and def not visible during the day. perhaps i need to find a super bright bulb option to help me out. anyone ever replace that blinker bulb with a super bright LED or something?
i also see you went with a flat black paint, i went with a high gloss lacquer, it looks amazing in the day and especially at night...a lot of reflection going on...but then again, my car has a continaul Silver Gray & Gloss Black theme to it... good luck w/ the rest of your install! |
Originally Posted by IndyRedBeast
(Post 1371905)
Originally Posted by v_therussian
(Post 1371906)
Originally Posted by umichchris
(Post 1372005)
Originally Posted by DKNewYork
(Post 1371997)
Yup. I did. :lol: Also the lens in front are tinted real dark. Messed up when painting it. One side is tinted front and back of the lens. Trying to get it as smooth as possible. But couldn't wait for it to dry. So I said f*ck it. Didn't want to waste time and proceeded with the install. Hope its still visible.
(Post 1372005)
i also see you went with a flat black paint, i went with a high gloss lacquer, it looks amazing in the day and especially at night...a lot of reflection going on...but then again, my car has a continaul Silver Gray & Gloss Black theme to it... good luck w/ the rest of your install! As for the turn signals. There is a 7W LED option right now. I bought a set to test, and it's pretty damn bright. It should be perfect for this black out mod. I'll probably test it tomorrow when I am doing another set of headlights and see if the person wants to pick it up. |
(Post 1372048)
Actually, I didn't find Nite Shade to be hard to work with. Prep is pretty key though, it's very advisable to sand the surface on the blinker piece.
As for the turn signals. There is a 7W LED option right now. I bought a set to test, and it's pretty damn bright. It should be perfect for this black out mod. I'll probably test it tomorrow when I am doing another set of headlights and see if the person wants to pick it up. Where did you get the 7w LED turn signals? I'm going to need it. |
