Upgrade idrive controller
My Ride: 02/2006 525i Titanium Silver Metallic
Manual 6-Speed
Full of WIN. You will have good knowledge about what you are getting into!
And Georgieb, I have to say, I appreciate your helpful posts man! I hope I can find time/$$$ to tackle the CIC retrofit!
My Ride: 2007 Black Sapphire 535i
The CIC retrofit and subsequent Combox upgrade rates right up there with my 3-Stage Manifold and ECU re-map this year. Two of the best things I ever did to my E60....
I tried and the iDrive doesn't work. It doesn't light up.
When I connect, I hear a noise in the dashboard ...?
I Have 04 '530D with CCC (I think), gps business.
The car has never had a special program, always in BMW garage for maintenance.
The old second connector (MENU) isn't use ?
If your GPS is business then you dont have ccc but the older mask and in that case the controller wont work.
What is the name of the system of my car ?
I had the mask, now I did the Retrofit CCC (ZBE -> low).
CCC_APP.C0C
I plugged the new controller, it lights up but the shortcut keys don't work.
I need to code "ZBE-> low_with_slopes", so that the shortcut keys work?
How to know the software version?
CCC_APP.C0C
My Ride: BMW e60 525IA 12/2003
Hi
If you now got the CCC navigation ( Navigation Professional ):
Yes you would have to code the ZBE to "low-with-slopes" with NCS-Expert
The CGATE have to be updated with WinKFP to the software stand ending on xxxx636 ( instead of xxxx627 )
Good luck
Regards
BenAnd
Good luck
Regards
BenAnd
