SAT NAV RETROFIT advice needed for 2006 E61
I have got the following parts bu some one hastolememy Idrive HIGH controller is he old version number and is incompatible, can someone confirm this:
Screen:[65.82-6 985 868] FSV: 5.09.05
CCC: [6583 6987689-02] (09-05) HW9.5
Controller: [6 941 801] HW.05 SW.0B
Also im thinking of buying a GT1 programmer, where is the best place to get the updated software and instructions?
DIS V57 and SSS V32 can be purchased off ebay.
THANKS IN ADVANCE.
THANKS IN ADVANCE.
THANKS IN ADVANCE.
THANKS IN ADVANCE.
I've done NAV retrofit as well
The controller that you got seems ok.
(#6941801 --idrive controller high forcefeedback )
There are several other parts # for the controller, but 801 will do the job. (why dont you install it and see if it works since you got parts ready???)
Do you have FAN attached to CCC?
if not, you'll need
#61120396722 --ccc fan cable
#65836933200 --ccc fan
Also new two slotted (dvd& cd) front facia trim and you'll be set!!
Good luck!!
yea it should work without recode. Mine works without going to the dealer. Now the only problem is that the map sucks and the lady speaks too muffled and fast =P.
Please also check that you do not lose any functions like steering wheel auto up/down for easy entry/exit and also engine oil measurement and such. I lose these 2 functions with the new CCC. But I got extra bluetooth and voice command in german.
My Ride: 2006 Audi A8 4.2TDI
Previous rides:
2005 E61 530d, 20" Breyton reps, Eibach springs, M5 bumper/mirrors/MFSW
2000 Audi S6 Avant, 18" OZ, RS6 exhaust etc
1998 Audi A8 4,2Q, 19" RS4 wheels, Remus exhaust KW coilovers etc
1986 Audi 100CC, funky fresh steel rims w plastic covers, rubber lip on boot.....
1987 BMW 320i, 15" alloys + rubber lip on boot :)
1982 Opel Ascona 1,6DL, tinted windows and a big-ass subwoofer :P
Originally Posted by nwilliams' post='969688' date='Aug 8 2009, 11:27 PM
I'd really like to know more about what you did?
In order to get the DVD player to interface with the iDrive and the screen what type of tear down was required? Did you have to pull apart a lot of the dashboard?
What's the difference with business and pro NAV...I don't even think we have business NAV in North America?
Do you have the small or widescreen display in your car?
Thanks in advance...
if not, you'll need
Good luck!!
if not, you'll need
Good luck!!
Originally Posted by wokingBigBoy' post='986404' date='Aug 23 2009, 05:27 PM
Thanks ordered the fan cable but did not have time to pick it up it will be installed this weekend I will have pics and updates by Sunday ;-) if it all goes fine. Thanks
Next bluetooth :-)
Thanks for those who helped!
Originally Posted by wokingBigBoy' post='991795' date='Aug 28 2009, 04:58 PM
Installed today any everything worked, now just need the latest maps dvd for sat nav to work.
Next bluetooth :-)
Next bluetooth :-)
RTSW cable to PIN 1
BR cable to PIN 5
WS cable to PIN 11
I need clarification on what RTSW/BR/WS mean. The unit is working but after about a hour of driving the CCC unit seems to heat the SAT NAV DVD and if you put another location in I normally get a read error so I think I may of wired the fan up wrong.
Thanks
Here you go.
Sw = Black
BR= Brown
Ws = White
RT = Red
Use the table on page 7 and the diagram. I don't really use the color code but rather use E1/E2/E3/E4 and match it to the diagram.
Thanks and the fan doesn't turn on immediately. takes a while or something...
Sw = Black
BR= Brown
Ws = White
RT = Red
My Ride: 520d M Sport
Titanium Silver
Retro fit's -
Professional Sat Nav
Footwell Lights
BMW Bluetooth
LCI Halogens with HID
Installed Professional Navigation today (Thanks wokingBigBoy for your help and advice) all is working and no coding required.
i went for a slightly older unit so i would not have any coding issues.
but i notice i dont have POIs like filling stations etc and i dont have the 3d view, does my car require a software update from the dealers to enable these.
Also 7 digit postcode was this with the latest DVD i am using 08-01
