MAx Front Tire size
Hello.
Im looking to change my wheel/tire setup
Will 255/35/19 on style 167 wheels fit the fronts without any rubbing issues?
my Current setup : 167's on 245/35/19 fronts and 255/35/19 rears
My next setup (if possible 255/35/19 fronts and 285/30/19 rears
So, will 255/35/19 front tires give me any rubbing issues ?
BTW (stock non sport suspension)
Thanks
Thanks
Hey man great thread. I have found out thru trials that. A 275 30 and 265 35 will fit and it makes the car feel so much better.
Just make you measure and use a tire size calculator. And fyi the 275 has the similar radius, circumference, sidewall as a 235/35
275 in the font?
im looking to put on 255/35 on the front. I think 285/30/19 rears are ok.
Wider tires in front will only make your steering even STIFFER.
If I were you, i would add wheel protection than anything else by running a higher profile than trying to play with the width of the tire.
Anyway,
To answer your question - Its hard to determine if 255/35/19 is going to rub since your offset is unknown. If "525iEnjoy" says it can and he has done it then I will take his word for it but once again, I would take wheel protection and safety over a wider tire
Anyway,
Anyway,
Anyway,
Thanks, The offset is 18 fronts and 32 rear!.
I definitely want to protect my wheels. that is why Im thinking 255/35 for the fronts, as it has a slighter higher profile than 245/35.
Am I correct?
BTW the wheels are Style 167 ( M6)
http://felgenkatalog.auto-treff.com/
6er E63 ff.
M6 8,5x19 vorne 255/40R19 ET 12
9,5x19 hinten 285/35R19 ET 17
6er E63 ff.
I just want to know if anyone is running this type of set. Otherwise, I'll just run 245/35/19 285/30/19
But would rather have more meat on the front tires (wheel protection) so I want 255/35/19 285/30/19
