Hello.
Im looking to change my wheel/tire setup Will 255/35/19 on style 167 wheels fit the fronts without any rubbing issues? my Current setup : 167's on 245/35/19 fronts and 255/35/19 rears My next setup (if possible 255/35/19 fronts and 285/30/19 rears So, will 255/35/19 front tires give me any rubbing issues ? BTW (stock non sport suspension) Thanks |
Hey man great thread. I have found out thru trials that. A 275 30 and 265 35 will fit and it makes the car feel so much better.
Just make you measure and use a tire size calculator. And fyi the 275 has the similar radius, circumference, sidewall as a 235/35 |
275 in the front???
Originally Posted by sachal007
(Post 1372574)
275 in the front???
Originally Posted by 525iEnjoy
(Post 1372572)
Just make you measure and use a tire size calculator. And fyi the 275 has the similar radius, circumference, sidewall as a 235/35 275 in the font? im looking to put on 255/35 on the front. I think 285/30/19 rears are ok. |
Wider tires in front will only make your steering even STIFFER.
If I were you, i would add wheel protection than anything else by running a higher profile than trying to play with the width of the tire. Anyway, To answer your question - Its hard to determine if 255/35/19 is going to rub since your offset is unknown. If "525iEnjoy" says it can and he has done it then I will take his word for it but once again, I would take wheel protection and safety over a wider tire |
Originally Posted by TheRacerBoss
(Post 1372721)
If I were you, i would add wheel protection than anything else by running a higher profile than trying to play with the width of the tire. Anyway, To answer your question - Its hard to determine if 255/35/19 is going to rub since your offset is unknown. If "525iEnjoy" says it can and he has done it then I will take his word for it but once again, I would take wheel protection and safety over a wider tire Thanks, The offset is 18 fronts and 32 rear!. I definitely want to protect my wheels. that is why Im thinking 255/35 for the fronts, as it has a slighter higher profile than 245/35. Am I correct? |
BTW the wheels are Style 167 ( M6)
http://felgenkatalog.auto-treff.com/ 6er E63 ff. M6 8,5x19 vorne 255/40R19 ET 12 9,5x19 hinten 285/35R19 ET 17 |
I just want to know if anyone is running this type of set. Otherwise, I'll just run 245/35/19 285/30/19
But would rather have more meat on the front tires (wheel protection) so I want 255/35/19 285/30/19 |
I understand about rim protection.. a 255/35 shouldnt rub since I ran 265's. If ya change your mind
:devil: 275/30 https://i47.photobucket.com/albums/f...8-15072436.jpg |
