M5 instrument cluster
#121
My Ride: 535XI
Engine: N54
Ok so today i remove my M5 cluster and re install my original, ACC error clear out as soon as i turn the car on, got into the highway and acc was working fine.
Any ideas how can i get it to work on my M5 cluster?
#122
Engine: N54
This thread says that cruise control has not worked after we installed the M5 cluster so this should not have been a surprise for you.
I have not given up on it yet. Just hasn't been a priority for me to try and sort it out.
Some things I want to look at would be to see if there is a different firmware we can flash to the Kombi. Or maybe the KGM needs to be re-coded.
It seems to me the canbus message does not match for the cruise control.
#123
My Ride: 535
If you guys want a working oil temp gauge but don't care too much about the other M-features, it might be worth considering a 6-series cluster. 630i would be appropriate for the 6 cylinders, and 650i for the 8 cylinders. Pre-LCI should have the variable RPM too (though I'm not sure if pre-LCI clusters work properly in LCI cars).
Just added an LCI 630i instrument cluster to my dad's 535xi, and everything works perfectly after coding
#124
My Ride: 535
Mine came from an LCI model. Maybe you just need to update with WinKFP
#125
My Ride: 535XI
Engine: N54
Just installed an M5 cluster in my 535. Cruise works fine
E60 M5 Cluster in 535xi - Working Cruise - YouTube
#126
My Ride: 535
#127
My Ride: 535XI
Engine: N54
Thanks TERRAPHANTM.
I bought a 08 cluster to replace the 06 i had and had the eeprom clear & coded by Terraphantm, i have my ACC back no more errors.
Https://vid.me/HQno
08 535XI
Https://vid.me/HQno
08 535XI
#128
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
Another Working LCI M5 Cluster Retrofit
I figure I’ll resurrect this discussion from a few months ago, because it looked like there was a lot of skepticism about getting this to work fully without errors, despite a few successes noted above. Well, I just did mine last night, and it’s functioning perfectly with no errors or tamper dot.
I purchased a March 2009 M5 cluster for my 2010 LCI wagon (born July 2009). I removed and resoldered the EEPROM to flash my VIN and clear the miles. After flashing the EEPROM but before coding, my cruise control was not functional, and I got the typical errors for transmission, EDC, and several others. Then I simply coded it with my custom MAN file from my original KOMBI and everything works. No errors, correct red line, correct oil temp, and transmission [P, D, R, gear] reports as the original cluster did, including with the SAT retrofit function.
I’m curious to see if there is a pre-LCI difference, so if anyone has a pre-LCI cluster (or LCI for that matter) that they’re struggling with, I’d be happy to help (share BIN files, flash, etc).
#130
My Ride: 535i Platinum Bronze, Cream Beige Dakota Leather, Sport Package, Paddle Shifters, Window Curtains, Nav, Heated seats and steering, 5% tint, 6000k HID, 2500k Fogs, 7000k Angel Eyes, Black Grill, Black Emblems, Tinted Head and Tail lights, Logic 7
hey are are you able to code a pre lci e60 m5 cluster to a 2008 535i and have the cruise still working?
