M5 instrument cluster
Old Dec 27, 2015 | 01:49 PM
  #121
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Ok so today i remove my M5 cluster and re install my original, ACC error clear out as soon as i turn the car on, got into the highway and acc was working fine.
Any ideas how can i get it to work on my M5 cluster?
Old Dec 27, 2015 | 05:03 PM
  #122
NoQuarter's Avatar
Engine: N54
This thread says that cruise control has not worked after we installed the M5 cluster so this should not have been a surprise for you.
I have not given up on it yet. Just hasn't been a priority for me to try and sort it out.
Some things I want to look at would be to see if there is a different firmware we can flash to the Kombi. Or maybe the KGM needs to be re-coded.
It seems to me the canbus message does not match for the cruise control.
Old Dec 28, 2015 | 06:15 PM
  #123
terraphantm's Avatar
My Ride: 535
If you guys want a working oil temp gauge but don't care too much about the other M-features, it might be worth considering a 6-series cluster. 630i would be appropriate for the 6 cylinders, and 650i for the 8 cylinders. Pre-LCI should have the variable RPM too (though I'm not sure if pre-LCI clusters work properly in LCI cars).
Just added an LCI 630i instrument cluster to my dad's 535xi, and everything works perfectly after coding
Old Feb 24, 2016 | 02:15 PM
  #124
My Ride: 535
Just installed an M5 cluster in my 535. Cruise works fine
Mine came from an LCI model. Maybe you just need to update with WinKFP
Old Feb 24, 2016 | 02:25 PM
  #125
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
E60 M5 Cluster in 535xi - Working Cruise - YouTube
How?
Old Feb 24, 2016 | 02:27 PM
  #126
My Ride: 535
Originally Posted by Kewill0360
How?
I didn't do anything special. Just coded my VIN to it, recoded the cluster with NCS Expert, and took it for a drive.
...Or are you asking how to update it with WinKFP?
Old Mar 24, 2016 | 01:14 PM
  #127
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Thanks TERRAPHANTM.
I bought a 08 cluster to replace the 06 i had and had the eeprom clear & coded by Terraphantm, i have my ACC back no more errors.
Https://vid.me/HQno
08 535XI
Old Aug 27, 2016 | 01:47 PM
  #128
GTYellowJacket's Avatar
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
Default Another Working LCI M5 Cluster Retrofit
I figure I’ll resurrect this discussion from a few months ago, because it looked like there was a lot of skepticism about getting this to work fully without errors, despite a few successes noted above. Well, I just did mine last night, and it’s functioning perfectly with no errors or tamper dot.
I purchased a March 2009 M5 cluster for my 2010 LCI wagon (born July 2009). I removed and resoldered the EEPROM to flash my VIN and clear the miles. After flashing the EEPROM but before coding, my cruise control was not functional, and I got the typical errors for transmission, EDC, and several others. Then I simply coded it with my custom MAN file from my original KOMBI and everything works. No errors, correct red line, correct oil temp, and transmission [P, D, R, gear] reports as the original cluster did, including with the SAT retrofit function.
I’m curious to see if there is a pre-LCI difference, so if anyone has a pre-LCI cluster (or LCI for that matter) that they’re struggling with, I’d be happy to help (share BIN files, flash, etc).
Old Oct 16, 2016 | 05:43 PM
  #129
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
2 cluser ready for coding only for pre-lci...
Old Aug 23, 2017 | 09:08 AM
  #130
alisaeed03's Avatar
My Ride: 535i Platinum Bronze, Cream Beige Dakota Leather, Sport Package, Paddle Shifters, Window Curtains, Nav, Heated seats and steering, 5% tint, 6000k HID, 2500k Fogs, 7000k Angel Eyes, Black Grill, Black Emblems, Tinted Head and Tail lights, Logic 7
hey are are you able to code a pre lci e60 m5 cluster to a 2008 535i and have the cruise still working?
